RPM Drops...fuel...temp...lights! HELP
ok ill be driving and out of nowhere... my rpm gauge drops to zero along with the fuel gauge and temp gauge at the same time the Service Vehicle light comes on along with the brake light, abs inop light, air bag light and ASR off light if i continue to drive for a while everything will go back to normal with the exception of the Service Vehicle light, most of the time everything is fine.. all gauges work with no trouble lights
what the hell does this mean?
Originally Posted by BlackY2KSS
ttttttt
It sounds like your are losing a battery/alternator connection while driving. Is your PCM connectors tight? What about you battery cables? Ignition Switch OK?
runs fine while these things are going on
would the car still run if i lost connections to the alternator?
