exhaust leaks and tuning problems
Old 07-06-2004, 08:58 AM
CHRISPY's Avatar
Default exhaust leaks and tuning problems
Hi guys,
What effect (generally) do exhaust leaks have prior to the O2 sensors?
I am getting a header leak by the flange and also a leak on both header collectors where the reducers are attached to the merge collectors.
Would this cause a huge tuning change requirement after I fix/weld these leaks?
Do exhaust leaks typically lead to idle problems?
thanks again,
Chris
Old 07-06-2004, 09:21 AM
HumpinSS's Avatar
I would assume so. The o2 will be seeing a super rich (IIRC) condition and start compensating for the extra oxygen in the exhaust. This will be reflected in your TRIMS extremly -
Old 07-06-2004, 11:58 AM
Ragtop 99's Avatar
Chris:
The exhaust leak can lead to idle problems. Depending on where the leak is, the scavenging can suck air into the collector and cause the A/F to be off.
