How to make linelock switch illuminate?
I installed my linelock a while back and used a switch from radio shack that is supposed to light up when you turn it on. My question is, how do I do that? It has three small terminals sticking out from the bottom, and I have two that are connected for the linelock (both 12 volt sources). The linelock itself works fine, but it just doesn't light up when I turn it on, and it'd be nice if it did. Anyone want to take a stab at it?
Edit: The switch also doesn't have any labels on it for the ground, power, or accessory.
if your using the slp linelock, or any other linelock kit where the switch provides the ground, you need to connect the 3rd wire to a +12 source.
if the switch has a led instead of a lamp, you can't do this, and will have to either install a relay, or resire the linelock to have the +12 switched instead of the ground.
Ryan.
Ryan.
