Vibration, Help
Vibration, Help
I have the constant vibration in 1st gear only on my 98 TA. It only happens when i accelerate in 1st about half to 3/4 throttle and goes away when i hit second. Anyone know what it can be? Thanks in advance.
mine did the same thing what are your modifications stock?? if stock i would check u joints and see if drive shaft is straight
if have adj. torque arm check the pinion angle
if poly trani mounts may be that
