Wheel Offset?????
Wheel Offset?????
I have a 1998 Trans Am that I want to put a custom set of wheels on. I bought a set of Centerline wheels for it (which are for sale if anyone is interested!) that were the same size as the Ram air but the offset must not of been right because they stuck out quite a bit. So....now I am looking at buying a set of 18's and I want to know what offset I need to get in order to "tuck" the tires under the car with no rubbing. the car has been lowered
1 1/2", if that matters?! Thanks!
Can anyone help me???
Can anyone help me?? No one has replied!
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html.
You say you want 18" wheels but you do not mention wheel width or tire sizes . . .
My recommendation:
Front, 18" x 9.5", 38mm to 40mm offset with a 275/35ZR18.
Rear, 18" x 10.5", 44mm with a 295/35ZR18
My recommendation:
Originally Posted by Xsta Z 28
https://ls1tech.com/forums/showthread.php?t=120716.
My recommendation:
My recommendation:
