input shafts
input shafts
I have a 2001 blazer that I'm putting a LS1 into and I'm trying to see if there is any differences in the tranny's. I heard that the only main difference in the 4l60e for the blazer and the t/a, ss, etc. is the input shaft is this true? If I upgrade to a 65e would this solve my problem?
Thanks
Thanks
LS1 (GenIII in general) transmissions use a different input shaft, 300mm converter and matching stator shaft. All three must be used together, you cannot mix and match shaft, converter and stator shaft. Also note that GenI/GenII bellhousings are different then GenIII (because of above changes).
