speedometer problem
Old 07-13-2004, 01:47 PM
andrew1's Avatar
Default speedometer problem
my car all of a sudden has a problem where the speedometer is delayed and slow. I have a 98 trans am a4. when i start to speed up from a stop the needle goes up very slowly and has about a 2 second delay. then when i stop it does the same thing. i took it into a shop and they said its either the gauge cluster or the speedo sensor. whats do you guys think and what should i try? also if it is the speedo then wouldnt my "check gauge" light go on?
andrew1 is offline
Old 07-13-2004, 03:17 PM
CamaroCain's Avatar
saw this same post in another forum, sorry does not belong here
CamaroCain is offline
