Not sure what to do about my problem. Maybe someone else has ran into it can help me.
I have a 346 w/6.0 heads and cam with a vortech blower on it. When I get on it it presures up the crank case enough to push the dipstick out of its hole and blowes oil under the hood and on the headers. I am not sure what else I can do to relieve the presure. It has a hose that runs from the PVC system to the intake of the supercharger but it must not pull enough of a vacum to keep the presure down. Does anyone have any ideas to offer. If you do please let me know I have a few of my own but I wanted to ask and see what other people have had to do. Pictures are helpful on this subject as everyone seems to word the descriptions of the parts a little different. But what every you have to offer would be appreciated. Thanks in advance!!!!!!
Jeff
Jeff
I'd do leakdown test (or have it done at a garage) to check for piston/ring damage. If you're pressurizing the crankcase, that's a common cause and there's no band-aid fix for it.
Both PCV lines...the one that goes to the intake and the one that goes to the TB need to be away from boost. They need to be upstream of the supercharger. Either line is capable of pressurizing the crankcase.
