Cam decision?
Old 07-15-2004, 04:37 PM
95maroman's Avatar
Default Cam decision?
I just built a 383 ls1 with around a 10.9:1 to 11:1 compression. it has stage 2 heads with springs up .620 lift. i want to run as much power on 93 octane and could careless about the drivability. Whats the biggest and most agressive cam out there thats good for staying in my compression. Also im looking for power mid to high-end, or just anything that will get me big #s.
Old 07-15-2004, 04:54 PM
Cstraub's Avatar
I've got a lobe that is 278 @ .050", lobe lift is 372. The biggest in cams is not your best choice, based on your max rpm level, where you want the power, the flow of the induction system, a camshaft can be selected. Please don't get caught up in the "my stick is bigger then yours". Just speaking from experience.
Chris
Old 07-15-2004, 06:59 PM
6600 rpm clutch dump of death Administrator
J-Rod's Avatar
Chris
Absolutely correct... What is your setup (in detail), and what rpm do you want to turn. What are the flow numbers on your heads with the intake in place? If you provide good information it is possible to get you a good cam.
As stated biggest isn't always best...
Old 07-15-2004, 11:02 PM
FASTONE's Avatar
Call Alan at Futral and get the same cam as Vince got, it only puts out 585 rwhp should do the job.Its in a 408 ironblock,240ish duration 114 lda around .650 lift,maybe a little more!!Its NOT that complicated
