gaskets/bolts needed for heads
Old 07-19-2004, 01:03 AM
Cerebrex's Avatar
Default gaskets/bolts needed for heads
I'm putting a new LS1 in my TA... the heads are off the new engine. What gaskets/bolts will I need to get this thing running, keeping in mind it still isn't in the car. Will I only need 2 head gaskets and a new set of head bolts?
Old 07-19-2004, 03:33 AM
jrp
SN95 Director
jrp's Avatar
are you just doing a head swap? if so then you'll just need 2 head gaskets and head bolts.
Old 07-19-2004, 09:39 AM
bigdsz's Avatar
At SDPC LS1 head bolt kit[ one head] part number 12498545 $16.95/set. 1997-2001 LS1/LS6 head gasket kit[both heads] part number 12498543 $34.95. Hope this helps.
Old 07-19-2004, 11:23 AM
KJ
KJ's Avatar
Bigdsz is correct you can use the #'s he posted or we also have a head kit that wll include everything but the installation!! We have cam only install kits, head only install kits, or head & cam install kits. Let me know if I can help in any way!!!
Old 07-20-2004, 03:09 PM
Cerebrex's Avatar
I'm putting a new LS1 in (complete engine). The heads are off of the new motor, so I need to put them back on. Is this all that I'll need to do it?
By the way, thank you very much for the part numbers!
Old 07-21-2004, 09:17 AM
KJ
KJ's Avatar
Yes That should be all you need. If you can't find anyone close that has them for you let me know. I have them in stock and can get them to you quick!!
Old 07-22-2004, 11:11 AM
Cerebrex's Avatar
Ordered the parts from sdpc and they should be here today or tomorrow. Thanks a lot, guys!
