Th350 In A 01 Ss
Old 07-19-2004, 02:23 AM
SuperSport01LS6's Avatar
Default Th350 In A 01 Ss
Ok Well Here Is The Story I Melted My Clutch Disk To My Flywheel At Rsd. Im Getting Rid Of The Whole Manual Set Up. I Have A Th350 A 6.0 Flywheel/flexplate 3500 Non Lock Up Tourque Convereter I Heard That My Manual 6 Transe Mount Will Work Just Fine I Have A Trans Cooler And All Little Things Like Shifter And Etc. Now What I Dont Have Is A Drive Shaft, Can I Use Mine Or No Would I Need To Have It Lengthened Or Shortened? Sorry This Might Sound Stupid But I Really Dont Have Too Much Knowledge Of Automatics. I Built My Ls1 And Am Making Ok Power With 409 At The Rear With The M6 With Just Full Valvetrain And Bolt Ons No Head Work At All Anyway I Know The 350 Can Defintly Handle That Power But Is Everything I Listed Up Top What I Need Im Sorta Going Low Budget And The Driveshaft IS Holding Me Back and what do i do about my tourqe arm Thank You
Old 07-21-2004, 04:45 PM
12secSS's Avatar
Cool
Here is what I learned from converting my A4 1998 Z28 to a TH400:
  1. You can use your stock flywheel, provided it has the dual pattern. I don't recall it on my 2001, but the 1998 had the SBC converter bolt pattern. Just requires 1/8" spacers.
  2. The TH350/400 will bolt up using the side bolts along the alignment pins, the bottom three and center top one are not used.
  3. You'll need a shifter for a TH350/400.
  4. You'll need the VSS from a 3sp 4L80 (the non-electronic trans in the late model trucks). This is available from GM.
  5. Since yours is an M6, you'll need to correct the speedo by multipling it 2.5 times. A4 going to A3 need only a connector to plug into the 3sp VSS I mentioned above.
  6. You need a spacer for the OEM trans mount to work. I just bought a BMR K-member and solid mount for the trans.
  7. You will need to lengthen your driveshaft to work. Be sure you do not need the large TH400 slip yoke, the 4L60E one will not work. It will work on a TH350 though. Not an issue with M6 conversions.
  8. You will need a dipstick tube, I chose the Lokar flexible, firewall mounted one from SummitRacing.
  9. Finally, you'll need to get a torque arm that uses an aftermarket TQ arm mount, or one that incoporates the trans x-member as well.
Hope this helps
Old 07-21-2004, 06:33 PM
Default cool
well this is what i got im not sure what u mean about spacers though i have the th350 ,the shifter, the 3500 billet stall, spohn body mount torque arm, 6.0 ls1 flywheel, but as far as drive shafts i dont have one that will fit im on a low budget i need to know what i have to buy if anyone has a driveshaft for sale for th350 let me know i will probably buy it but thanks for your help 12secss i dont mind about my speedo not working its my fun car u know
Old 07-22-2004, 12:07 PM
12secSS's Avatar
The spacers are due to the converter being in the trans fully engaged, but the flanges on the converter are 1/8" away from my flexplate ... so I need 1/8" spacer to take up that 'slack'. Good luck finding a DS, I am having mine custom made.
