LM-1 WB O2 sensor
Old 07-19-2004, 08:28 PM
Bill's 02 Z-28 SS's Avatar
Default LM-1 WB O2 sensor
Hi Folks
Just received my LM-1 WB O2 sensor - still need to get the bung welded. The unit can take 0 to 5V as an input. I want to log RPM data with the O2 data. It appears that I have purchase a RPM converter but I would think the PCM has that analog data already. What do I need to do is get it into the LM-1, if it is possible. Does anybody know if it possible and what I would have to do to get the signal (What wire,etc) into the LM-1??
Thanks
Bill
Old 07-19-2004, 09:18 PM
HumpinSS's Avatar
if you hook it to the ac pressure sending unit you willbe able to log that via efilive and have map and rpm to go with it
