Whats the best way to disable Knock Retard at specific RPM?
My knock (unless my car has some magical knock problem) has got to be false because I have pulled timing and added plenty of fuel, and it still occurs at the same RPM every time. I have never even heard the engine knock at high RPMs. So what is the bast way to go about removing knock retard for a specific RPM, and would it be safe to rely on readings from surrounding RPMs to determine in the future if any knock is occurring? I have already searched for stuff banging, but that shouldn't cause knock at a consistent RPM, and I have run top-engine cleaner.
Do you try running any Octane booster or 100 octane fuel in it? This would be my first thing to try as it would be the easiest but how much KR are you getting and @ what RPM range?
