Patriot Golds installed (pics) and the "BuckeyeROC" install tool
Old 07-24-2004, 04:41 PM
King of Pigskin Knowledge
BuckeyeROC's Avatar
Default Patriot Golds installed (pics) and the "BuckeyeROC" install tool
Here are a few pics of the Patriot Golds I just installed.
Pics 1 and 2 have 4 valves with the Golds, and 4 with the stockers. Pic 3 has all the Golds on.
I think I used the most ghetto spring tool known to man. 2 electrical junction box covers with "U" shapes cut into them, a couple washers, and a rocker arm bolt, which was on my bad rocker arm that is being replaced anyway. $130 for a spring install tool? NO WAY!!! I just used what was lying around. I used that Autozone spring tool to remove the stock springs, but it would not work with the dual springs, couldn't grip both the inner and outer springs enough for the install. So I HAD to improvise. Honestly, it works GREAT. Patent pending
Attached Thumbnails Patriot Golds installed (pics) and the "BuckeyeROC" install tool-patriotgolds1.jpg   Patriot Golds installed (pics) and the "BuckeyeROC" install tool-patriotgolds2.jpg   Patriot Golds installed (pics) and the "BuckeyeROC" install tool-patriotgolds3.jpg   Patriot Golds installed (pics) and the "BuckeyeROC" install tool-springtool.jpg   Patriot Golds installed (pics) and the "BuckeyeROC" install tool-springtools.jpg
Old 07-24-2004, 05:00 PM
JMBLOWNWS6's Avatar
That is awesome
Old 07-24-2004, 05:12 PM
BuckeyeROC's Avatar
Originally Posted by JMBLOWNWS6
That is awesome
Improvise, adapt, overcome.
Old 07-24-2004, 06:30 PM
LS1TECH Sponsor
foff667's Avatar
that is one of thee ugliest spring tools ive ever seen, but hey it works lol ok now everyone his the electrical dept. at your local home depot lol.
Old 07-24-2004, 06:37 PM
kenkaru's Avatar
I'm glad I'm not the only one that does stuff like that!
Old 07-24-2004, 07:55 PM
Cheatin' Chad's Avatar
Neccessity if the mother of invention
That is indeed ghetto. I'm glad it worked for you.
Old 07-25-2004, 08:04 AM
HavATampa's Avatar
Awesome!! What are you using for head gaskets, duct tape and aluminum foil?
Old 07-25-2004, 08:34 AM
PREDATOR-Z's Avatar
Good improv man.
However let me point out that with the heads off, you do not need any of these top tools. A regular old fashionned C clamp spring tool will do the job!! Can be rented for 5 bucks/day
Old 07-25-2004, 12:33 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Nice
I bet you'll enjoy those springs!! We prefer to run the Patriot spring in just about every package we sell... Besides they're the best looking spring available!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-25-2004, 01:47 PM
BuckeyeROC's Avatar
Just the driver side head was off, had some problems with a rocker letting needle bearings go on that side and dropping the retainer in the pushrod hole.
These springs do look good, can't wait to get this thing started up.
Old 07-25-2004, 04:59 PM
Black Z/28's Avatar
Actually, in this case, "stinginess is the mother of invention".
If it works, who cares what it looks like. Good job.
Old 07-25-2004, 05:08 PM
Billiumss's Avatar
This must be some kind of joke....
Old 07-25-2004, 05:31 PM
som_ss_01's Avatar
Migyver
Old 07-25-2004, 07:11 PM
BuckeyeROC's Avatar
I wish it was. I went to a few auto parts stores and ended up buying a tool that works similar, looks like a big crow bar type thing. You hook it up to the rocker stud/screw and pull the handle down to compress the spring while it's on the head. It said it was for GM springs, but it was too big to work at all on the LS1. It was too big too use even with the head that was off the car. So it was either make my own tool or spend $130 and wait a week.
Old 07-25-2004, 09:37 PM
Squintz Palladoris's Avatar
WOW!
Old 07-25-2004, 09:56 PM
Broken041's Avatar
That is exactly what comes to my mind. But hey, my hats off to you for making it work.
