how hard is it to install a 10-bolt?
Old 07-30-2004, 01:00 PM
heyitsTaJay's Avatar
Default how hard is it to install a 10-bolt?
is it hard? can it be done in my garage from home or should i take it to a shop?
any install write-ups....
TIA J
Old 07-30-2004, 01:05 PM
Scalpel's Avatar
TIA J
If you have a jack and some jackstands you can do it at home. It's really easy.
  • Jack and support the car
  • remove the wheels
  • remove and hang calipers out of the way, remove rotors
  • remove parking brake cables
  • put a jack under the rear and raise it a bit
  • loosen the lower shock nuts and slide the shocks out
  • remove torque arm
  • remove driveshaft
  • slide the brakelines out of their holders so they're free from the rear
  • remove PHB
  • remove LCAs
  • remove misc electrical connectors
  • Slowly lower the rear out after you have checked for no left over connections or brake lines attached
Install is reverse of removal.
Old 07-30-2004, 01:08 PM
would u pay 350 to have it done?
Old 07-30-2004, 01:11 PM
Scalpel's Avatar
Nope. I have the tools and patience to do it.
That's probably a "fair" rate, though.
Old 07-30-2004, 01:26 PM
Tranzor's Avatar
It's easy, just time consuming... rear end swap can be done in about 4 hours on your own.
Me and a couple of friends of mine completed two rear end swaps in under 6 hours, so it helps having an extra set of hands or two.
Old 08-02-2004, 02:52 AM
Tech's Avatar
Do the shock bolts last when removing. You can let the rear hang on just the shocks while you take everything else apart. If you have problems with re-installing the torque arm, jack the rear end up and down until the bolts slide through the TA/rear end.
