Dropping K-Member for rod bolt install, what am I missing?
King of Pigskin Knowledge
Ok, when you "drop" the K-member to get the oil pan off. What all needs unbolted? I got the motor mount bolts out, engine suspended by a hoist, and the 6 k-member bolts out and the 4 sway bar bolts out. What else needs to happen to drop the whole k-member down to get enough clearence to drop the oil pan and get at the rod bolts? The shocks? Thanks.
Originally Posted by DEEZ98Z
Yeah you can just unbolt the shocks from the lower a arms... it is only another 4 bolts
Originally Posted by BuckeyeROC
Cool, then is that it? Or is there anything else I need to unhook to drop it a few inches?
