Ran last night in "Thunder" trim.
Went to HRP last night for some shake down runs in "Thunder" trim <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> .
Full interior, plus an assortment of lead shot filled weight bars, and the most gas the car has had in it in probably two years <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> .
Raceweight came in right at 3250 lbs.
Running the MADMAN tq arm now, and his trick LCA's, and PHR. Also had some brand new 28x10.5x15's.
Made 4 runs, two of which the car launched so hard I pulled it into 2cnd right on the launch.
3rd run I ran .06 off my best ever ET ( which was ran at a RW of basically 200lbs less ). The bummer is that I don't get near the growth out non w tire, and I was basically shutting it down and coasting the traps.
The car feels ROCK stable with the MADMAN rear suspension! Hope to get back soon for some more playing <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Re: Ran last night in "Thunder" trim.
Very nice Pain <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I look forward to seeing your car run at the shootout.
<small>[ October 17, 2002, 06:37 PM: Message edited by: Mike Hoffpauir ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PaiN:
<strong>The bummer is that I don't get near the growth out non w tire, and I was basically shutting it down and coasting the traps.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Larry,
Have you thought about a possible gear ratio change to compensate for the non-growth? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Mir
Mir
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Y2K_WS6_T/A:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by PaiN:
Mir</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hi Mir,
Yeah I have some plans for the car after Thunder is done, and the appropriate gear set for these tires, or buying a set of 29's would sorta be a waste.
I really didn't figure there would be THAT much difference in the tires concerning rpms/traps. Just my inexperience...lesson learned.
Larry
Larry
Sounds killer, Larry! So how do you like the torque arm?
Interesting that you get less growth from the non-W tire... I never considered that there would be a difference, and haven't run anything but 28x10.5 ET Drags (but I do have a pair of 28x10.5 stiff sidewall slicks on the way).
Nice video, BTW <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Was that with the torque arm set where we talked about via email? I'm still getting mine dialed in.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>Sounds killer, Larry! So how do you like the torque arm?
Nice video, BTW <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> Was that with the torque arm set where we talked about via email? I'm still getting mine dialed in.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks George,
Yep that was with the tq arm set just like we talked about. Brian told me to try it set like that. I really liked it.
The only way I can describe it is that with his setup on the car, I seem to get a much better response to the quick changes I can make between runs Like shock settings. With the old setup...It never hooked consistently enough to get a real feel for any of the changes I would be making. Last night the rear seemed to be planting the same every time, and every run I made a slight adjustment to the front shocks only, it was like dialing up the front end lift I wanted.
I'm very pleased with the setup! I think with a little fine tuning the car will cut consistent rock steady 1.3's.
Larry
Larry
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CAT3:
<strong>Nice wheelie clip PaiN. where do you get a Madman T.A.? Is it Strip and Street or damn near all Strip purpose built? TIA.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can pick one up from Madman Racing , check the sponsor links to the right.
It's one beefy TQ arm, with ALOT of adjustability.
As far as driveability...ask Coach, he has one on his car, and I'm pretty sure he daily drives the car with no problems.
<strong>
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The "W" tires are meant to grow a lot bigger, they are meant for a more stable top-end
Thats why those cars that run in the classes that have to run a "true" 10.5" tire always ET better with a W tire because its a bit wider and grows a lot more to make it more stable
<strong>
Cool <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
I may have to try a set of "W" tires in the future and see if I like them.
Awesome wheelie Larry. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I'm bring my video camara to the shootout and I definately want to get some good shots of your BAD BAD HOT ROD. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Tom <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
LS1Tech Co-Founder
"little" wheelie? MY ***! haha. That was a cool video Larry, someday maybe I'll have a car and be able to go to the track to see those wheelies of yours in person <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
You do realize that seeing that stuff makes resisting a TH350/brake even more difficult <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
-Tony
-Tony
Tony, how's your car looking? Are you still planning on having it back together for the Thunder Shootout? ...haven't heard anything in a little while.
LS1Tech Co-Founder
The car is still sitting at MTI, waiting for a new block to be built for it. Once the block is done, we will pull it apart and swap everything over. This should happen before the Thunder Shootout, fingers crossed..... only two weeks!
-Tony
-Tony
