6.0 liter heads lower the compression to............................
Old 08-03-2004, 06:04 PM
highspeed specialist's Avatar
Default 6.0 liter heads lower the compression to............................
On a stock LS1 the cr is 10.1:1, the stock LS1 heads are 64cc, so when you install ported 6.0 liter heads with 72 cc your compression becomes.........?
Some people say 9.8:1 some say 9.6:1 some say 9.4:1
Please help me I'm confused.
Old 08-03-2004, 06:11 PM
TT-TECH Veteran
Inspector12's Avatar
If you look at the sticky in the internal engine section it showes it to be @9.1-9.2. Mine are at 73cc and it is around 9.25:1 just to give you an idea.
Old 08-03-2004, 06:21 PM
Is your bottom end stock?
Old 08-03-2004, 06:28 PM
Inspector 12 you said you found a good deal on some pistons. Where? what kind? How much?
Thanks
Old 08-03-2004, 08:52 PM
TT-TECH Veteran
It was/is I have atleast one more than likely two cracked pistons or ring glands something along that line, I won't know for sure untill I take it apart. I'll PM you with the details of the pistons and rods I found. Advertising around here can get you in trouble LOL!
Old 08-03-2004, 09:29 PM
Crude's Avatar
Yes, the 6 liter truck heads will lower the compression. Please check out the following link. These heads for sale were done for a boosted application. Very nice heads CNC'ed and hand finished by Brian Tooley at Total Engine Airflow.
325 CCM at 4.030 bore.
https://ls1tech.com/forums/showthrea...63#post1618763
Steve
Old 08-04-2004, 07:30 AM
1point3liter's Avatar
Out of curiosity has anyone here actually CC'd their truck heads or just gone by what they read on the board? I just went through the process on one of my combustion chambers and it apeears to be 75cc's. *shrug*
