What tools are needed to remove the backseat, passenger seat and belts.
How do you do it and what sizes?
thanks again. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Super Moderator
Re: What tools are needed to remove the backseat, passenger seat and belts.
-13mm bolt on the bottom-front of the seat cushions
-13mm nut on each side of the seat back
-18mm nut for the seat belts (under the plastic panels in back)
-Torx (not sure about size) for removing the seat belts on the sides of the seat cushions (I use an allen wrench that fits close)
In that order <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Front passenger seat is 4 13mm nuts.
<small>[ October 22, 2002, 10:08 AM: Message edited by: Reckless ]</small>
Thanks Reckless <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Hopefully this will help the car get into 12's tonight. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Yeah, just make sure if you use an allen key that you use one that's big enough or you'll strip those little torx bolts. Especially after they've been taken out and put back in as many times as mine have. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
