B&M trans cooler
B&M trans cooler
Anyone have tips for my install of my B&M trans cooler? The instructions are not very clear and are not for a camaro install. Please help!!
http://bowlingss.com
I just installed mine using the Dope Install because I have a cold air induction.
Good luck.
Bill
By the time i got to look at it i had installed mine. It was really easy and i found a really easy way to install it in front of the radiator. there are holes in the bracket below it so you can just run the hoses through those and down the frame and the will come out right where the line are where you need to make your connections to the factory lines
