Whats the chance of this passing CA emissions?
Was looking to maybe drop this in and was just wondering what the concensus of this passing the siffer is, LTs and Catted Y to follow. I can get around the LT inspection problem. Competition Cams LS1 camshaft.
The grind numbers are:
CC LS1 3722R/3722R HR14+2
And its specifications are:
Intake Duration @ .050: 224
Itake Lift w/1.7 rockers: .581
Exhaust Duration @ .050: 224
Exhaust Lift w/1.7 Rockers: .581
The cam is ground with a 114 LSA and it has 2 degrees of advance ground in.
Please note that the cam DOES have XE-R lobes on both the intake and exhaust.
What do you all think?
I have a guy out here that promises to get me to pass the test by bumping the idle a little. He said that a 225/225-112 could even pass with proper tuning. Worst case scenario is that I will just change the registration to NC and then be X piped with true dual dumps.
Does the 2* advance help out in the whole process here too? I thought the XE-R did something funky though at times to the emissions, that was my only concern. I just really wanted a .583
Originally Posted by Jamie33
224's on 114's will pass
just be careful they dont do the visual
Originally Posted by WS6 RULES
If I read it right he is keeping the cats. And nothing illegal about headers. I also live in Ca and was wondering how much lift and duration I can get away with.
Since they use the rolling chassis sniffer test for putting a load on the wheels here where I am in Cali, I doubt bumping the idle will help much.
The less overlap the better chance you have for passing. Your cam has -4* of overlap so it's got a good chance to pass the sniffer, good luck with it...
Dan
Dan
