Drag Racing Tech
weight loss
Old 11-12-2002, 06:05 PM
blu3bird's Avatar
Default weight loss
What are some good things to take out or off?
Old 11-12-2002, 07:52 PM
LARRY01Z28's Avatar
Default Re: weight loss
here ya go.
First step....
Buy a lightweight optioned car
Free stuff....
9...!ABS
21.5!AC compressor
8.5.!AC condenser
....!AC fan motor
13.5!Airbag and bracket, passenger's
4...!Airbag, driver's
....!Air dam
1...!Air filter
5...!Amp, Monsoon
4...!Antenna, bracket, and motor if applicable
....!Ashtray & lighter
....!Blinker switch
2...!Bolt lengths, extra
....!Brake pedal pad
23..!Bumper, front reinforcement and brackets
21..!Bumper, rear reinforcement and brackets
34..!Carpet & Sound deadening
50..!Catback
15..!Cats
9...!Center console
....!Coating, under carpet
4...!Crossmember brace
....!Cruise control
10..!Dash
20..!Door panels
11..!EGR, air pump, & harware
....!Emblems
....!Fan, 1
....!Fan shroud
5...!Floormats
3...!Foglights and brackets
....FRA mod
....!Gas, Extra
2.5.!Glovebox
1...!Grill insert
4...!Hatch cover
2...!Hatch shocks
....!Headlights
....!Headliner
3...!Head unit
....!Head unit/AC console trim piece
8...!Heat sheilding
9...!Heater core
1...!Hood shocks
3...!Horn
3...!Inner fenderwells, plastic
....!Liscense plate brackets
....!Liscense plate(s)
....!Misc. junk in the car like keys, garage remote, change, owner's manual, etc.
1...!Owner's manual
3...!Panels, under steering wheel
5....Panhard rod brace, upper
....!Parking brake
....!Power brake booster
....!Parking brake handle
....!Power seat motor
11..!Power steering pump, pulley, idler pulley
....!Power window motors
1...!Rear view mirror
9...!Seatbelts (rears and passenger's)
34..!Seat, passenger's
19..!Seats, rear
3...!Sheetmetal, extra double walled
....!Shifter ****
7.5...!Side impact bars
35..!Spare tire and jack
7...!Speaker panels, hatch
5...!Speaker panels, rear passenger's
15..!Speakers
35..!Spoiler (Weight measured on a Pontiac)
....!Spring isolators
2...!Sun visors
14..!Swaybar and brackets, front
....!Taillight(s)
2...!T-Top holders
....!Under car tow points
1...!Washer fluid pump
9...!Windshield washer fluid
2...!Windshield wiper reservoir
3...!Wiper arms
3...!Wiper motor
....!Wiring, Excess
Wallet mods....
3...Airlid, aftermarket
3...Chromoly LCAs
3/9.Carbon fiber driveshaft
14..Chromoly A-arms
30.5Chromoly K-member
....Draglite wheels
....Drag slicks or street slicks
....Drilled axles
24..Dry cell battery
10..Electric water pump
....Fiberglass door skins
30..Fiberglass hood
....Fuel cell
18..'99+ fuel tank for '98 cars
....Headers
....Lexan glass
....Lightweight clothing
35..Lightweight brakes, front
....Lightweight brakes, rear
10..Lightweight flywheel
13..Lightweight springs and shocks
....Lightweight steering column
6...Lightweight steering wheel
10..Manual rack and pinion steering
....Plastic fuel tank, late model
....Powerglide, TH350, or M4 transmission
17/29.Racing seat
....Shortbelt mod
....Skinny front tires
15..Spool
20..TQ converter, small
....Underdrive pulleys
And finally....
Wash car inside, out, and underneath
Potty break
Go on a diet yourself!
complimants of colonel.
Old 11-12-2002, 08:12 PM
blu3bird's Avatar
Thanks I have a 01 ram air trans am with heads and cam, need to lose about 200lb.Going to do the seats and sway bar for starters,and use drag light rims.
Old 11-12-2002, 10:48 PM
2000SILVERTA's Avatar
blu, this is SAC, with the silver car from TCD friday. My car was probably 200-250lbs lighter than yours the other night. That was with stuff that you could remove or put back in in ~1hour. Including wheels. You saw what I had removed and done, easy stuff.
