Whats more important...correct idle airflow, or correct IAC counts?
I adjusted my idle airflow vs. ECT to the correct airflow, and now my desired IAC counts are between 250-280 at all times. So which needs to be right? I seem to have given myself a slight case of the cruise control effect...not quite enough to keep me accelerating, just enough for it to take the car a little longer to slow down while in gear and decelerating without the brake. What gives?
I've been playing with Idle Airflow a bit more too, and noticed the same thing. The higher the idle airflow value, the more IAC's.
How high do you have your values?
I have a theory that once you open your throttle for a cam or whatever and increase the idle airflow to match, the pcm doesn't account for that when calculating what iac position it needs for a certain amount of flow. That could cause a cruise control effect because the iac would be opening too much to get the airflow needed under the throttle cracker tables. It would also throw off your desired iac counts i would think.
