Calibrating Speedo after gear change
I've ordered a 12 bolt with 4:11's I know the speedo will be off because its set to the stock 3:42's. The car was tuned after my H/C and I traveled almost 3 hours to get that done, and the nearest LS1 edit garage is 2 hours away. Do I have to drive all the way there(2 hours) to calibrated the speedo (and pay $400-500) or drive 3 hours and see if they will adjust it for a small fee, or is there an easier way to to it?
normally if you have your car tuned at a place they will change little stuff like gear changes for free, it takes like 10minutes. The only way to do it is with an edit program though.
Hey i remember your car from eastside i think, the blue firehawk? The car sounded bad ***. Eastside will change the speedo ratio for no charge if you had the car tuned there, their great guys. The drive there does stink though
