11's for now till the bugs are worked out
I'm getting re-tuned next week so I should be able to improve on my past best of 11.5 at 119.Since then I got a k-member, lower control arms, weld skinny's up front,X-pipe to 3" duel bullets,fuel pump,injectors,and a S3 tb to test against my 80MM BBK.I'm hoping when the temp ddrops this fall to take a trip to atco in NJ.There almost below sea level- That track is good for 2 tenth's just going there so that leaves 3 tenths for everything else I changed to make up for and cold weather to boot.I should get a 11.0-10.8 out of it NA then I can spray my TNT 150 shot.Gotta run 100% NA before I spray.I dont plan on being in the 11's for long NA.I know if I spray it's a easy 10 right now but want to see what it does 100% NA first
