Noise under hood, can't tell what it is
I have a '99 Camaro SS and there's a noise under my hood coming from the engine. I was told it's coming from the passgener side.
I can't hear the noise because i'm hard of hearing (wear hearing aids) and can't tell from small squeaks or crap like that going on if it's low, I can't even tell if the brakes are squeaking unless it's bad enough I can feel it.
My gf tells me there's a printer like noise or squeaking noise coming from the passgener side. I asked my bro to listen to it, I looked after the belt tenisor which is on the passgener side and he pointed to it too
(the top one, near the EGR), I then took a socket and put it on with a breaker bar, pulled a lil on it and held it, the noise went away.
I replaced the belt recently and it only made it a bit quieter.
It has been like almost a year since he hear it last (he's too busy with his auto parts store trying to keep up with a car and motorcycle payments)
The gf still says it's making noise on the passgener side
Could it still be this making a printer like noise? I was considering getting a Katech tenisor but haven't had the spare funds until now.
And last I heard, the katech tensior doesn't come with a pulley and I'd either have to take the stock one off the stock tensior. Or get a "larry" pulley from ASP (last I heard they made limited supply and won't make more unless they get a high demand for them)
Check all the pulleys on the engine. Several idlers and the tensioners. Most of them can be taken off the engine and taken apart and regreased. I had a noise that sounded like a rocker arm clattering just when the engine was cold. Found out it was the a/c clutch. Bought a new one to replace it but ended up shooting the old one with lubricant and let it sit over night. Wiped up the excess and it's been quiet ever since.
I don't believe the tenisor on the top of the engine close to the battery can be disassembled due to a high tension spring inside which can cause harm if attempted to.
