Loom fuses - what do I need?
I'm fitting my LS1 in a kit car, so I am customising the loom. On the switched live circuit (pink wires) in the engine loom, I will be putting a fuse. It seems that the original car had a fuse to each part of the loom (left ignition stuff and right, plus other bits). Do I need to wire left and right to different fuses, or can I connect all the pink wires together and route through one fuse?
What fuse rating(s) will I need?
