DTC P0106 H help!
DTC P0106 H help!
Hi everyone,
My car ( 2002 ZO6 ) got an SES light, when i checked it, it turned out to be P0106
Does anyonw know what that mean? and what is the solution to this problem.
Thank in advance.
Thank in advance.
Manifold Absolute Pressure System Performance
Strange that you're seeing that in a 98 PCM... maybe it's turned on there too?
When my car was a 2000 OS it had P0106 disabled by default from GM... but when I upgraded to a 2002 OS it was not turned off by default and I was setting it ...
I think something to do w/the bigger cams sets this code... my buddy w/a tuned 2002 has this code disabled (he has a TSP cam)
edit just saw it was for a z06 .. do you have a cam in it? or is it stock? if it's got a cam then prolly just need the code turned off... if it's stock sounds like the most likely cause is a vacuum leak... has the intake manifold been off recently?
Guys, please help! My cars Idels like if it has a cam! I am not sure if it does, but the dyno says stack cam! 345 rwhp! And some times it nealy shuts off when I start it!
