Cam Question!
Old 03-30-2003, 12:36 AM
1LastZ's Avatar
Default Cam Question!
I just had a comp cam .563/.563 222/222 112 installed a week ago. It constantly turns off, and also takes me a few tries to turn it on. When driving the car pulls great, the problem is stoping at red lights or reversing. I had a 3200 vig converter, B & M trans cooler, transgo Shift kit, and dyno tunning also done to it at the same time. Has anyone had this problem. Or does the car need to be broken in. (2002 Z28 A4) How can you fix your car from running "lean"? If that is the problem. Sorry for the long post, I just know that someone in here can help. Thanks guys!
Old 03-30-2003, 12:51 AM
JS
JS's Avatar
Default Re: Cam Question!
Get the car up to 185/195 operating temps.
Sit in the car and have someone check the IAC counts while your in nuetral of drive.U want them at 30 to 40 and this should stop the problem.U can adust the IAC alittle or drill the TV blade how to achive the proper counts.
I did mine by adj. the IAC sensor.
I run a 224-228 in my auto and it idles great..
JS
<small>[ March 30, 2003, 12:52 AM: Message edited by: JS ]</small>
