Broke two studs....what size to replace?
Any idea what size or part # to replace two broken wheels studs (on the rear driver side)?? I'm assuming any autoparts store will stock them, just not sure what length or thread pitch.
Originally Posted by blaSSt
I just replaced all mine with ARP studs. They are M12x1.5. Factory style were in stock at O'Reillys.
Cool thanks!
I have a general idea of the replacement process...but just to make sure, let me verify:
-Remove the caliper (2 15mm bolts)
-Pull the Rotor (is it bolted on?)
-Hammer the broken stud out
-Push new stud thru, use washer and lugnut to pull it completely thru
sound about right?
Now to just find some replacement lug nuts.
