Freeze Plug
What kind of freeze plug? Is there an LS1 specific freeze plug? Only thing I am away of using a freeze plug for is the EGR hole in the intake manifold on older LS1's.
There are 4 threaded holes in the LS1-LQ4 blocks. Two are for oil, the other two are for coolant. They are all universal from one block to another, just make sure you use a dab of teflon paste or pipe dope to make sure you get a good seal.
