Need help installing comp 1.85 roller rockers asap
Im installing the comp roller rockers right for a friend and i need to know what to torque the guide bolts too, and also how do you adjust these. Do i need to use a feller guage or what, I have never installed these comps before so Im lost. Please any help will be great, thanks
If you are hydraulic you set preload so no feeler gauge used.Torgue rocker studs to 22 ft lbs with blue locktight.If the car has centerbolt valve covers (99-02),then you will need to remove the oil baffle in the drivers side valve cover and the boss for its mount.
If this is for solid roller set clearance as per cam card.I used about 1/2 turn of preload and had good results with stock lifters.
