Drag Racing Tech
Removal of Passenger Air bag
Old 03-09-2003, 08:21 PM
NOSfoggedWS6's Avatar
Default Removal of Passenger Air bag
Does anyone have any info on how to do this?
Thanks!
Old 03-09-2003, 08:42 PM
BlackhawkSS's Avatar
Default Re: Removal of Passenger Air bag
you gotta pull the dash back far enough or off to get it out. PITA. then you gotta deal with the air bag light or do as i did and take the instrument panel out and still some black paper behind the panel to block the light <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
i tried doing the 2 ohm resistor thing and it didnt work to get rid of the light.
good luck
Jerry
Old 03-09-2003, 08:46 PM
Can LS1Edit be used to turn off this light and any codes it pulls?
Old 03-09-2003, 11:08 PM
SJM Manufacturing Inc's Avatar
The light can be disabled in VERY quickly without going into your dash...takes about 5 minutes. You can disable it by cutting the lamp-feed wire located behind your glove-box.
Its your B1 (brown wire)on the 24 way connector pack located behind the glove box. Just find the wire, and clip it and tape it off.
This ONLY shuts off the lamp on your dash and does not effect any other part of the circuit.
Hope my tip helps you or anyone else out!
Steve
Old 03-09-2003, 11:25 PM
LS1LT1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by steve10:
<strong> The light can be disabled in VERY quickly without going into your dash...takes about 5 minutes. You can disable it by cutting the lamp-feed wire located behind your glove-box.
Hope my tip helps you or anyone else out!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Does that definitely work on all (models/years) LS1s?
My brother ('00 6 speed) changed his steering wheel and tried that and it didn't work, unless he got the wrong brown wire maybe? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
