410cid Stroker/Short Blocks
Old 09-07-2004, 01:14 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Default 410cid Stroker/Short Blocks
410.x CID Iron Block
4.045 Bore
4" Lunati Crankshaft
Lunati Pro Mod Rods
Diamond -15cc Pistons
Iron 6.0L Block
Main Studs
O-Rings
This New Stroker Is Available with Stage 3 Heads or as a short block!! The heads have been opened up to the 4.045 bore & have receiver grooves!!
This shortblock was designed for big nitrous use
$5800 for the Shortblock or $7400 with Stage 3 Heads!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
