PAGING MADMAN...
PAGING MADMAN...
Hey Brian, this is Gabriel, i need your expert advise......
Im trying to put some extended wheel studs in the car but I can't seem to find the ones that work. The first set I got were too small, so I exchanged them for another set and now these are too big. The first set I got were the ARP 100-7701 studs and the second set were the ARP 100-7702 studs. What should I do?
Re: PAGING MADMAN...
why use a 7/16 lug? if you are going to go away from the stock 12mm size, you should step up to a 1/2" if anything
also i dont know of any 7/16 studs that will fit our stock axles. you could drill the holes out and use the 7702s though, but like i said if you are going to drill, might as well go 1/2"
if i were you i would just get the 7708s and get 12mm lug nuts
5/8" studs with an 11/16 shoulder here fwiw
i really dont care about the thread size. im going to be using weld pro stars. and i already got the 7/16x20 lug nuts. i just need the right stuid to fit in tha dam axle.
Chevyguy is right, if you dont want to drill out and retap your axles you need to use the ones he mentioned LOL <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
Chris
