Stiffer Coil Spings With Iron Block
Old 09-08-2004, 05:01 PM
gollum's Avatar
Default Stiffer Coil Spings With Iron Block
It seems you would need stiffer front coil springs going to an iron block. Does any body have any suggestions. Maybe SLP's stiffer OEM replacement so my headers will not scape?
Old 09-08-2004, 05:04 PM
badls1's Avatar
use the LT1's. I was using the LS1 with iron block, no problems.
Old 09-08-2004, 05:21 PM
necrocannibal's Avatar
I have a 408 iron block with the stock LS1 springs and am having no issues. Why do you think you would need stiffer springs??
Old 09-08-2004, 05:26 PM
BLK02WS6's Avatar
I have a 6.0L iron block - no issues - no stiffer springs are needed.
Old 09-08-2004, 05:40 PM
gollum's Avatar
Does the front set lower with the iron block? How much lower? I think it weighs 100lbs more.
