First time dyno run. Need advise...
I will be dyno'ing for a baseline and being an A4, I don't know what should I do. Should I run it through the gears normally or floor it at a certain RPM? or floor it at a certain MPH? Will it go into a lower gear? The dyno guy doesnt have much experience with A4 either. Also, should I run the converter locked or unlocked. I will be monitoring with EFILive Pro.
Thanks for the help. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Re: First time dyno run. Need advise...
Go up to 80mph on the dyno and then floor it. You want to dyno in third gear (1:1)
If you hit it earlier than that you will likely downshift to second.
Cheers,
Chris
Cheers,
Chris
