How much tranny fluid for 4L60E with a deep pan
Old 09-09-2004, 09:08 PM
Rincon2003's Avatar
Default How much tranny fluid for 4L60E with a deep pan
I was wondering if anyone knew how much tranny fluid I would need for a 4L60E with a deep pan on my silverado.
Old 09-10-2004, 04:02 PM
IRACE2's Avatar
Seven quarts.
Old 09-10-2004, 10:39 PM
FoRmuLa_DriVa's Avatar
no dipstick?
Old 09-11-2004, 09:22 AM
koolrayz's Avatar
Old 09-11-2004, 12:52 PM
MM98's Avatar
If your flushing the tranny & converter it's 12qts... If just the pan then it's 6qts.
Old 09-18-2004, 09:33 AM
Farmer2's Avatar
MM98 has the same quarts I do.
Trans was out and flipped and drained (transgo kit installed) new Vig TC and 2 quart more trans pan.
I put 11.5 in and topped it off with another 1/2 quart. Right on the fulll mark at temp.
Old 09-18-2004, 03:14 PM
DEEZ98Z's Avatar
I just put in a new tc last night... I have a deep pan with a drain plug so all I did was drain the pan, then pull the trans and converter. It took me about 11-12 quarts to top it off. (dont know exact amount because I had some tranny fluid left over in a couple different gallon jugs)
Quick Reply: How much tranny fluid for 4L60E with a deep pan
