Air Conditioner
Old 09-13-2004, 07:17 PM
white2001formula's Avatar
Default Air Conditioner
Alright, this probably doesn't go in this section, but after I installed my heads and Cam my AC/heater doesn't blow air out of the front vents. It only blows on the lower vents by your feet, and out the vent for the defrost. What did I do wrong? Did I hook something up backwards. The vents that do work, do blow hot/cold air. The condensor is also getting cold. Everything seems to be working normal except it's not in the right spot. Help Please!!!
Old 09-13-2004, 08:20 PM
So after my Heads and Cam install, my Air conditioner/heater has stopped blowing front vents. It blows out the vents by the floorboard, and up on the defrost vent no matter what setting it's on. (Hot/Cold/Defrost etc) What did I do wrong? The condenser is getting cold. It still is creating hot/cold air, just not blowing out the right vent. Is there something that I didn't hook up, or something I broke. The only thing is that I had an ASP Crank pulley that we installed. Other than that, I'm pretty sure that everything was hooked up exactly where it was before. (Grounds, EVAP lines) Help Please
Old 09-13-2004, 09:04 PM
John_D.'s Avatar
Usually this means the little vacuum hose that goes from the back of the intake, to a little fitting between the engine and pcm, is disconnected.
It feeds vacuum to power the vacuum motors for the flapper doors.
Old 09-13-2004, 10:35 PM
wrencher
wrencher's Avatar
Check the vacuum line at the back of the intake. Make sure it's connected , not pinched etc.
Old 09-26-2004, 12:00 PM
Thanks, finally got around to doing it this weekend. It works!
Old 09-26-2004, 12:01 PM
Old 09-26-2004, 04:56 PM
WILWAXU's Avatar
I merged the 2 threads. Keeps all the info together
