Stock MLS head gasket vs Cometic
Old 09-15-2004, 10:11 PM
Green Thunder's Avatar
Default Stock MLS head gasket vs Cometic
Forced induction...
Big difference or not?
Old 09-16-2004, 12:49 AM
y2khawk's Avatar
If you don't need a large bore size or funky thickness to change the CR, and don't have the infamous notched heads the GM MLS ones will do just fine. And are MUCH cheaper.
FWIW, i'm running 6.0L MLS gaskets and ARP studs. They hold 20 to 22 psi just fine so far
Quick Reply: Stock MLS head gasket vs Cometic
