What does this sensor do??
Originally Posted by jrp
thats the oil pressure sending unit. often time broken during an intake install.
****....well, mine broke. How the hell can this be fixed????
Thanks for the help anyways.
And what exactly will happened if this sensor is not pluged in?
Location: sojourning....looking for my city whose builder and maker is God.
OIL PRESSURE sending unit. what do you think it does
you can pick up a new one @ a gm dealer or check with SDPC. where exactly did it break off?
It pretty much broke from the bottom. I can take a picture real quick and show you.
Would this be a simple swap if I buy a new sensor?
Simple swap with the socket you have to buy from Advance or Autozone. It's about a $9 socket.
Originally Posted by CANNIBAL
No need for a picture b/c the sensor is f'd.
So, there's a "special" tool needed for this install?
One more quick question. Has anybody ever tried installing that oil sensor unit while the intake manifold is already installed????
GM Part #: 12562267
No, don't even try. It's next to impossible. It only takes 20 minutes to pull the manifold.
GM Part #: 12562267
GM Part #: 12562267
Ok, I wish just trying to save some time. But, if it's that difficult I'll just remove the intake manifold, which really doesn't take too much time.
thanks for the info.
