Patriot Heads And Spark Plugs
Old 09-19-2004, 02:08 PM
hydfixer's Avatar
Default Patriot Heads And Spark Plugs
I have a set of Patriot LS6 stage III heads, went to install my TR55 plugs and found that the plug holes on the heads don't have a taper seat just a flat surface like a gasketed plug. Does this take a differant plug or is this a screw up? A regular plug that takes a 13/16 socket won't work, the socket won't fit in the hole.
Old 09-19-2004, 02:42 PM
Tally TransAm's Avatar
i use tr55's in mine with no problem.
