what does this code mean
Old 09-19-2004, 05:00 PM
tedscamaro's Avatar
Default what does this code mean
i know it has to do with my knock sensors but i just put new ones in about 5000 miles ago when i rebuilt the engine in my 98 z. the code is p0332. please let me know what it means before i start to go and buy more parts
Old 09-19-2004, 05:51 PM
Another_User's Avatar
P0332
Knock Sensor 2 Circuit Low Input (Bank 2)
It could be bad, or it could be damaged wiring. Were you careful with the install? Did you make sure you didn't pinch off the wiring with the intake manifold?
Old 09-19-2004, 10:07 PM
tedscamaro's Avatar
im pretty sure that i didnt do any of that stuff but ill check anyway. does that code mean that it is both sensors if not then which one?
Old 09-19-2004, 10:27 PM
horist's Avatar
no... only knock sensor 2 .. which I believe is the back one
Old 09-20-2004, 06:56 PM
He is right, it is the back one. You probably damaged the wiring putting it on. Are you running an LS6 intake?
Old 09-20-2004, 11:20 PM
tedscamaro's Avatar
nope i was but decided to wait but isnt it about $45 for a new one
