good dnyo # or not with heads,cam.6.0l
i have p.p 5.3l heads stg2 wich are milled for 11.1 compression on a 6.0l and a a custom cam wich is 226/230 590 114 on a A4 wich i made 403hp-388tq i was dissaponted i thought i had more what do you guys alright or is there something wrong with setup.
Six speed= bad, A4= good. Did you open up the combustion chambers on the heads to match the bigger bore? That could be worth some power if you didn't. Not to mention that broken spring problem you had. I'd find out if it was just a faulty spring or if something else caused it. None of the other springs out there have broke, and they are run on much more aggressive cams. That's what makes me think something else might have caused it.
