how to fix bucking
how to fix bucking
Hey guys. I just got my torquer cam installed and am starting to tune it. What all do i need to adjust to get my car to pull itself along in first without all the bucking? At the time my idle was at 825. I'm gonna try raising it to 900 and also increasing the idle air some more. Would this put me on the right track? thanks
reduce the ve table at 400-800-1200-1600 by 60-80-90-90
Also check www.ls1tuning.com and chech the idle forum
Originally Posted by P Mack
I still had bucking after I lowered the ve table at low rpms, but when i hand smoothed the ve table in that area it seemed to help a whole lot.
If you're asking if you should lean out your ve, than you need to log your car again and make sure your Lterms are where they need to be at part-throttle. Once your Lterms are in line, then modify your high/low octane tables as I posted.
Well, I didn't have a whole lot of time to mess with it. I tried a tune where I leaned out the ve some more and pulled 3 deg. of timing from 1200 on down in the ho table. It almost seems like it bucked worse than it did before. On the histogram, all the low rpm regions indicate lean, but it still surges at start a little bit. It's worse with a cold start but it still surges a little with a warm start. I haven't done anything with my throttle blade yet. Would it make a difference if I opened that up some to get the iac down to a lower level? Also i have my running airflow at like 9.2. How do I know how far to raise that?
Open up your throttle blade based on your IAC counts. If you open it up until you see about 35 that is a good rule of thumb to keep it from surging, but each car seems to like a different number to get a good balance between surging and the cruise control effect.
Just make your desired airflow equal to what you see at idle. That's not really that important because the pcm learns how much airflow you need to sustain your idle speed regardless of what you set your desired airflow to. It will help if you unplug your battery or something cause it won't have to go as far to relearn the idle trims.
