Box of rocks noise after installing moser
Old 09-29-2004, 10:07 AM
salspmp's Avatar
Default Box of rocks noise after installing moser
I have had the rear end for about two year. And just installed it on my newest fbody, the 00 ws6. The car makes a "box of rocks noise" intermitantly when slowly taking a corner. I don't recall this noise on either one of my lt1 fbodys. It was tight putting the driveshaft in with the new rear end. Only about a 1/4 inch to spare. Could this be that the driveshaft is getting pushed a bit forward and rubbing inside the tranny? Any thoughts?
Old 09-29-2004, 11:13 AM
Motorboater
SilverGhost's Avatar
i had that happen to me.
pulled the wheel off and found that one of the retaining bolt things for the drum for the E brake had come out and was caught in the ABS reluctor wheel. because it was moving around in there it wouldn't make the noise all the time, mostly just around turns like you are describing.
