11.74@117.05 1.58 60' cam only full weight
My previous best was 11.77@117.61 1.66 60' with 4.10's in the stock 10 bolt then I was having problems with my ASP crank pulley.So I put my stock pulley back on with no short belt added a Moser 12 bolt with 4.30's and ran a 11.74@117.05 1.58 60'. Not too bad with all the weight I added with my Moser. I probably made over 100 passes this year and the best DA that I've seen was 2400ft. I'm pretty happy still trapping around 117. It felt good dumping the clutch at 66-6800 rpms(stock clutch). If i can keep hitting 1.5's 60's then I think I could run 11.4xx with better air and a new crank pulley.
Originally Posted by 99 Pewter TA
Dropping the cluch at 6600 RPMs, damn I can't imagine doing that. I need a 12 bolt. Congrats on the new time.
btw: thanks
Originally Posted by 2001 Pewter WS6
Especially when you hear the car hit the revlimiter while the lights are dropping...
I ended up going 11.71@117.83 with only 1.65 60' spinning over the past weekend. I don't know how long the stock clutch will last. Hope to the end of the month or at least 12 more passes.
