Moser 4th Gen Specials through Oct 31st
The replacement unit for any broken 10-bolt. Even a bone stock ls1 can break a stock rear, the 12-bolt with eaton posi is the best replacement for the daily driver/weekend racer.
Moser Complete 12-Bolt w/ Eaton Posi
$1900.00 + $25 Mandatory Crate Charge = $1925
- Includes 12 Bolt Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Eaton Posi (30 spline), Pro Street gears, 1350 series pinion yoke, chrome cover and assembly.
Options:
- Performance TA Cover 160.00
- 4-Channel ABS/TCS Setup 100.00 (Must reuse stock exciter rings & press onto new axles OR have Moser press on new rings)
- 3-Channel ABS Setup 100.00
- Exciter Rings Pressed on Axles 100.00 (4-Channel ABS/TCS users)
- Upgrade to 33 Spline Posi 100.00
* Shipping for 12-Bolts: This unit comes truck freight collect. The trucking company will collect the freight cost at time of delivery. Estimated Costs of truck freight shipping is between $85-150, depending on your area.
Gear Choice: Your 12-Bolt includes your gear ratio choice of: 3.08, 3.42, 3.73, 3.90 ($45.00 Charge for 3.90 Gear Option) 4.11, 4.30, 4.56.
* Add 12-Bolt Installation Kit for $100 (All hardware/fluids needed for installation).
* Note: Additional hardware/fluids will be needed for installation if you do not purchase our kit.
Want the durability of a Moser Full Spool, but don't want to lose additional HP to a 9 inch? Less overall weight and less rotational weight = less parasitic loss (Less drivetrain loss).
Complete Moser 12-Bolt with Full Spool
$1655 + $25 Mandatory Crate Charge = $1680
- Includes 12 Bolt Housing, M/E Custom Alloy Axles, wheel bearings, wheel studs, retainer plates, Full Spool (30 or 33 spline), Pro Street gears, 1350 series pinion yoke, chrome cover and assembly.
Options:
- No 3-Channel ABS available on spool units.
Want a stronger housing/posi package for higher HP, but streetability?
Moser 9" Auburn Limited-Slip Posi Package
$2060
Includes:
- Housing/Axle Package for F-Body w/ Torque Arm Bracket
- Assembled Center Section - Auburn Posi
- 28 or 31 spline axles
- Gear Ratios: 3.50, 3.70, 3.89, 4.11, 4.30, 4.56
- 1350 series yoke / aluminum pinion support
- JAZ case
Options:
3-Channel ABS Only (Not available on any Ford 9" rearend)
4-Channel ABS & Traction Control: $100
Exciter Rings Pressed On Axles (Required for 4-channel ABS): $100
Aluminum Case (Saves 15 lbs): $155
Add Fill/Drain Plugs: $35 each
Moser 9" Detroit Locker Package
$2095
Includes:
- Assembled Center Section - Detriot Locker
- 28, 31 or 35 spline axles
- JAZ case
Options:
Lightweight Gundrilled Axles (Recommended for only 35+ spline axles): $100
Star Flange (Not recommended for extensive street use): $65
Moser 9" Full Spool Package
$1835
Includes:
- Assembled Center Section - Full Spool
- 31, 33 or 35 spline axles
- JAZ case
Options:
You can give us a call at 973-340-4069 OR place your order online (www.ttperformance.net/shop) and we will adjust the prices on our end. Ignore the shipping charges that the shopping cart program quotes you, we will manually adjust for shipping depending on the unit.
* Shipping for Moser 12-Bolt Rears: Truck freight collect. You pay the shipping company direct, usually runs $85-150 depending on the area.
* Shipping for Ford 9" Rears: Since the Ford 9" comes in various boxes and is not completely assembled (Center section/gears are assembled) this unit arrives via UPS Ground. Shipping charges are generally from $80-140, we can let you know when you provide your zip code.
Note: Since the Moser products are on sale, online order discounts do not apply to these items.
Thanks,
Matt Sorian
Options:
Options:
$2060
Includes:
- JAZ case
Options:
$2095
Includes:
- JAZ case
Options:
$1835
Includes:
- JAZ case
Options:
Thanks,
Matt Sorian
Originally Posted by pewterta
also how do you know if you have a 3 channel or 4 channel...
i have a sensor above the pumkin on my 10bolt
i really want a 9 inch!!!! my car is a six speed!
thanks!
thanks!
no traction control = 3 channel
I need to order the soft locker on a the 9inch but that option is not on your website and Ihavn't been able to get an answer on the phone in two days. Is there another way I can order this from ya'll?
Hey Matt, if you are in the shop tommorrow give me a call if you can I need to get you the info for this order asap so I can order the driveshaft. I called a couple of times today and couldn't catch you.
Thanks,
Charles
Thanks,
Charles
Moser 12 bolt
My name is Thomas I left you a couple of message already and I wanted to know was my 12 bolt shipped yet and if possible could i get the tracking number.
Originally Posted by NoseUpChromeDown
A spool is sort of like a coupling that directly connects the axles and keeps them insync @ all times-no clutches, ect. to slip. Hard to break. Not good for the street, but doable...
Very doable, some of us do it every day. Its not for someone who likes to complain alot about little stuff.
