anyone uses the deep trans pan for their Ls1's, if so how many total quarts to use?
i got the tci transmission deep trans pan and i was curious how many quarts does it take? i used 8 quarts so far and its hard reading that dam dip stick for an accurate reading, can some tell me how many quarts to fill up the deep transmission pan? thanks
Look at the dip stick and see how you fluid level is. If it is low then add a little at a time. And then check again. You should clean off the dipstick and stab it in and leave it in for about 3 seconds adn then check the level. If you add a little over dont be worried because There is a drain plug on the tci pan.
