March pully fit with a Roll Master w/o machining?
I remeber hearing talk about the ASP pully needing to be machined to fit if you had a Roll Master double roller timing chain. Does the same hold true for the March pullys or will it go on with a Roll Master w/o any modification? And while I`m asking, what size belt are guys using with March pullies and the short belt mod?
Thanks,
Eric
Thanks,
Eric
